AZ COMPLETE Acura TSX Projector Retrofit FS $450 shipped!
COMPLETE Acura TSX Projector Retrofit FS SOLD!!
For sale is a 100% complete Acura TSX retrofit.
Everything is currently installed in a set of 95 headlights. They're okay but have some yellowing. If you really want to make these perfect, pickup a set of clear lenses and swap them out. I'm selling this setup cheap simply because I would recommend putting them in a nicer set of headlights, however if you want to plug and play you can have TSX projectors in your car in 20 minutes!
What's included:
95 headlights with Acura TSX projectors that are in perfect condition. Obviously being that these are installed already they have the corners ground off so they're ready for SC300 headlights.
The prefabbed TSX brackets you can buy off the forums (can't remember who I bought them off of). These brackets allow factory adjustment
OEM Denso Slim ballasts with OEM ignitors. These have a connector on them ready to go to the custom harness below
Custom wiring harness. DO NOT plug HIDs directly into your stock wiring! This wiring harness has the proper relay for perfect HID function. No flickering, no hesitation, just perfect OEM HID function. It has a power wire directly to your battery, a ground wire to your chassis, and a power on wire that connects to your existing headlight connector so it will turn on the HIDs with your factory headlight controlls.
Phillips 85122+ D2S bulbs. These bulbs have maybe 30 hourss on them tops. I didn't use this setup very long before selling them car.
Everything will be shipped assembled for protection. The ballasts and wiring harness will be properly packaged and seperated from the headlights so everything is protected in shipping. If you want to transfer these to your own headlights feel free to ask me any questions as I personally did the retrofit on these. There's $600 into these so this is a huge bargain at $450 shipped!
THESE ARE SOLD!! Thanks!
I am also on Supraforums as Dangerzone, supra411 as Klaus, and ebay as maverickosu. My itrader ratings are solid. Interested parties will be PMed my personal cell phone number so I'll be available to answer questions!
What's included:
I guess they're not really as bad as I remembered lol
not too bad I guess, but these would really be killer with clear lenses. Anyway like I said headlights or not there's $600 in conversion parts alone NOT including what the headlights might be worth so pick these up for $450 and save a lot of cash!
interested, but the projectors on both headlights are not exactly flush with the housing. On the first pic there is a gap at the bottom, and the 2nd pic there is a gap all around.
any way to fix that?
These are sold though! Mods can lock. Anybody can feel free to PM me about the retrofit as I did it personally and definitely learned a lot during the process.
nwscoobie
03-28-15 11:20 PM
S2dannyKeo
03-28-14 03:39 PM
JeffTsai
12-06-10 05:25 AM
JnC
13
04-22-08 06:22 AM
