IL FS: Greddy / AEM / GTE coilpacks & Igniter / 5sp OBD2 ECU / Titan / Paxton
Nissan Q45 Throttle Body 90mm - $80 shipped/paypaled
- includes TPS
Unorthodox Racing Cam Gears (1 available)
$150 shipped/paypaled EACH
-Slightly used
![](http://i44.tinypic.com/181a3m.jpg)
![](http://i43.tinypic.com/11s37dy.jpg)
![](http://i40.tinypic.com/1566bfb.jpg)
6 GTE coil packs + igniter
$205 Shipped/Paypaled
If buying separately:
Igniter: $110 shipped/paypaled
Coil Packs: $110 shipped/paypaled
Overall good condition and (almost) everything needed to go distributor-less. All you need are the wiring clips that plug into the coil packs. They can be bought from Elmhurst Toyota
Coil Pack Clips Part# 90980-11246
![](http://i44.tinypic.com/24ay0bk.jpg)
![](http://i40.tinypic.com/2lxdunp.jpg)
![](http://i41.tinypic.com/vzya78.jpg)
Aem Injector Driver
$200 Shipped/paypaled
-Comes with all the papers for the wiring information
-Allows ECU’s that have a saturated injector (High Impedance) drive circuit to trigger Peak & Hold (Low impedance) injectors
![](http://i42.tinypic.com/2cp5b1j.jpg)
Titan Motorsport cam gear
$80 Shipped/Paypaled
![](http://i43.tinypic.com/10fdjdl.jpg)
![](http://i39.tinypic.com/2mr7g3n.jpg)
Paxton (rebranded) External Fuel pump.
$115 shipped/paypaled
Description:
These are the pumps that started it all. These fuel pumps are durable, reliable, and good looking, and they support high horsepower. Featuring a 600 lbs./hr. flow rate at 13.5 V and 45 psi, they are perfect for the daily driver that doesn't run like a daily driver.
MSRP: $325+
![](http://i39.tinypic.com/6teko2.jpg)
![](http://i41.tinypic.com/11vic1k.jpg)
- includes TPS
-Slightly used
Aem Injector Driver
Description:
MSRP: $325+
![](http://i44.tinypic.com/2rhlanm.jpg)
the AEM deals with injectors (it will be able to run low impedance injectors when your ECU requires high impedance injectors).
The coilpacks and igniters should be the only things required to go distributor-less. The proper wiring will be needed. I can supply you with the wiring diagram if needed.
neurocity
General Classifieds
12
03-19-11 08:18 PM
bzebern
SC400 / 300 Classifieds
08-03-09 08:01 PM
