MI -10 furl rail 2jzge
-10 furl rail 2jzge
I have a freshly built -10 fuel rail for the 2jzge with 14mm injectors o-rings holes. my boddy and I are using the same as this one.
The rail is polished, and tapped for -10 oring fitting, which means that you can use -10 JIC or -8 JIC to -10 oring (i have -10 JIC fitting for supply and -8 JIC for return). the rail is also tapped for the 3 brackets.
I will include the injectors bungs that mount on the lower intake manifold.
$160 i can include the supply and return fittings for the rail for $15 extra.
a picture on my car
a picture on my car
gldndrgn14, This is a single feed. the holes are the holes to mount the rail on the manifold. bolt size is 8x1.25. the brackets are just flat aluminum part with two holes it would be really easy to make i could make it for you fo an extra $10, because i would have to buy the material. really easy i can take a picture to show you how i mounted it on the manifold.
That-Guy, i can have one manifold soon for you PM me if you are interrested.
blazer84
SC400 / 300 Classifieds
10-10-11 10:16 AM
Eminence
01-17-10 11:35 AM
dejacky
02-01-09 08:26 PM
