CA 2JZGTE JZS147 aristo wiring harness for swapping!
Aristo engine wiring harness as pictured, ideal for 1gen gs300 swap/SC300 jzz30 swap. very nice and clean, all intact parts. if you have a gs300 all you will meedto do is extend all the wires to fit LHD instead of rhd. ignitor parts all perfect, all coilpack plugs nice and unburnt, no random stuff destroyed -a good, clean platform to start from.
$Sold.
What you will get: complete harness;
In summary:
this is a complete harness for installing a 2JZ-GTE from an Aristo into your usa model 2jz-ge equipped 1gen gs300 or sc300. with addition of the current GE harness, you will have all the pieces to complete a full oem toyota computer install in your GS300 to run the Aristo 2JZ-GTE. I did a full 2jzgte swap into my sc300 with an identical (and not as nice) harness which required much more work rebuilding.
some wiring swap info.
if you want to run a 1jzgte, you can de-pin the 2jzgte wire and pin them into the 4 grey 1j connectors. I have a full set of 1jz-gte jzz30/jza70 ecu plugs, $60 (shipped contiusa)
pix:
http://picasaweb.google.com/wanganstyle/2jzHarnessSuper
$Sold.
In summary:
pix:
rsos1
12-30-14 06:06 PM
Automan
13
11-04-13 01:07 PM
