CA 52mm MK4 Supra aluminum radiator+TT shroud+ OEM new hoses
Old 07-04-09, 04:52 AM
wanganstyl
wanganstyl's Avatar
Default 52mm MK4 Supra aluminum radiator+TT shroud+ OEM new hoses
Ideally picked up SF bay area. No leaks at all, holds water (and cools your car) perfectly. Fits perfect in all SC300 and MK4 Supra, plug and play for NA 2jz-ge and tt 2jz-gte and NA+T single turbo. Compatible with all fan shrouds and radiator hoses that fit in SC300 body and MK4 supra
$200 cash picked up
TT OEM Toyota Radiator shroud with pictured crack (only 2 months of use from dealer new) - not very hard to repair, I would if it would fit in my BMW.
$30 cash picked up
OEM 2jzGTE TT Toyota Top and Bottom Radiator Hoses- 2,200 miles from NEW. Fits PERFECT because its OEM Toyota.
$35 shipped contiusa
wanganstyl is offline
Old 07-17-09, 08:50 AM
wanganstyl
wanganstyl's Avatar
bump to the top.
Old 07-22-09, 10:52 AM
wanganstyl
wanganstyl's Avatar
aluminum radiators are shiny
Old 07-31-09, 01:40 PM
wanganstyl
wanganstyl's Avatar
bump to the tops!
Old 08-07-09, 11:34 AM
wanganstyl
wanganstyl's Avatar
bumps for plastic oem radiators!
Old 08-09-09, 09:47 AM
wanganstyl
wanganstyl's Avatar
nobody has the need for a metal radiator now?
Old 08-10-09, 02:58 AM
wanganstyl
wanganstyl's Avatar
oem hoses ichiban.
Old 08-17-09, 10:23 AM
wanganstyl
wanganstyl's Avatar
bumps@! to the top
Old 08-20-09, 12:44 PM
wanganstyl
wanganstyl's Avatar
bumps to the top for cooling system upgrade to new stuff.
Old 08-20-09, 07:56 PM
bzebern
bzebern's Avatar
bump for you buddy
its so freaking hard to sell a radiator i have been selling mine for the last 4 mos
bzebern is offline
Old 08-23-09, 06:22 AM
wanganstyl
wanganstyl's Avatar
why, all silly ghetto peeps buying 24" rimzzz instead of proper cooling?
Old 09-09-09, 10:45 AM
wanganstyl
wanganstyl's Avatar
bumps to the tops.
Old 09-09-09, 10:48 AM
RX7 RAGE
RX7 RAGE's Avatar
Who makes that radiator?
RX7 RAGE is offline
Old 09-23-09, 03:14 PM
wanganstyl
wanganstyl's Avatar
CX racing radiator, its a 52mm alu, probably same manufacture or similar as mishimoto
Old 10-05-09, 02:53 PM
wanganstyl
wanganstyl's Avatar
bumps to the tops.
Quick Reply: CA 52mm MK4 Supra aluminum radiator+TT shroud+ OEM new hoses
