CA 2jz-GTE BPU swapped partout: Denso 550's+sdm TTC twins partout, TT alternator, DP
breaking down items to components.
items already sold:
intake manifold
coilpacks
avail:
2jz-gte Throttle body, TRAC deleted with new toyota OEM sensor with warrenty $145 shipped
all sensors are excellent and are avail individually, PM with what you need-
2jz-gte longmotor with complete head+block+rear sump oilpan+valvecovers, no electronics. includes installed oil pump, waterpump - basically add your eletronics and turbo setup, intake and exhaust manifold choice and you are ready to go.
$2250 pick up only. 2200 miles on it, still on break in. Pictured ancileries NOT included
6mt parts changeover for 2jzgte- if you have a manual transmission and heavy duty clutch, you will want this- toyota designed part for a reason.
$200 shipped contiusa, you get all parts required with NEW OEM toyota dampener, all hardware
parts reference:
http://mkiv.com/techarticles/auto_to...ension_damper/
items already sold:
intake manifold
coilpacks
avail:
parts reference:
2jz-gte USDM downpipe only fits sc300 with 2jzgte swap or MK4 supra TT.
1jz needs aftermarket pipe not found in usa often, JDM 2jzgte turbos also needs a different downpipe.
my downpipe is only for USDM 2jzgte turbos on 2jzgte engine in a sc300 or mK4 supra.
will NOT fit 1jzgte, will not fit 2jzgte with jdm twin turbochargers
