AL LS400 4 Piston Calipers-Upgrade for Supra, SC300/400, IS300, GS300, ETC
I have a pair of MINT front 4 piston calipers off a 98 Lexus LS400. They are in very good condition and the car had very low miles on it. I know there are a few guys on here with lexus' as dailies. Or if you know a buddy that could use these, let them know.
This is a upgrade for both TT and NA MK4 Supra. I doubt TT supra guys would changeover but TT calipers are iron and these full aluminum so about 8 lbs lighter. And these calipers are bigger in size than the TT calipers. I believe the TRD brake upgrade for the Supra is basically the LS400 calipers. NA Supra has 2 piston calipers I believe so this is a significant upgrade.
Also bolt on upgrade for all sc300/400. All you need to do is modify the dust shield a little to compensate for the bigger rotor and caliper.
And its a bolt on upgrade for IS300 after you buy the adapter brackets. It may be a bolt on upgrade for GS300/400 but not 100 percent sure.
Comes with 2 calipers, 100 percent complete hardware, used pads, and mounting bolts.
PRICE: 210 dollars SHIPPED
PM me or email at driftmistertwo@yahoo.com
They go for a bit less on here, somewhere around 160-180 shipped. They are also not an upgrade from TT calipers, as the rotors on the TT are bigger, and the caliper is part aluminum, and there is a much larger pad selection.
Having said that, I have the LS brakes on my car, and it stops very well and looks great.
Thanks Tavarish for clarifing, almost tossed my TT set up in the trash.
OP Closing this, 1st post here.
Rules Sticky here:
https://www.clublexus.com/forums/sc4...-for-sale.html
Rules Sticky here:
supraguy2
03-06-12 11:06 AM
