MD Looking for a gauge cluster with working needles and low miles
Jubay,
Sorry for Jacking up you Thread, This is a SC300 cluster it will work for a SC4, the Tach. reading will be off.
To: Soarer, The cluster came from a 1993 car However, the needles are Red, not Orange. The red needles can not be upgraded or color changed as the needles are sealed. Those needles were made for the 1995- and up cars. The newer cars from 1997 to 2000 have a different set of plug in harnesses. This cluster uses the older connectors which are found on 1992-1996 cars, the 97 dash harness connectors won't fit the older type cluster. The orange type needles came with the 1992-1994 only. So by the process of elimination, the needles are of a newer type cluster, newer than the 1992-1994, but the cluster it self is not a 1997 to 2000. So the cluster is from a 1995-1996.
To: Rawkus, This is a SC300 cluster it will work for a SC4, the Tach. reading will be off.
Acrad
GX - 2nd Gen (2010-2023)
12-14-19 07:35 AM
