NC WTT apexi power fc boost control kit for 1jz soarer ecu
just as the title states. i have an apexi boost control kit that i want to trade for a stock soarer 1jz ecu (manual transmission version). the boost control kit is for the power fc. you just plug it into the side of the power fc and hook lines from your wastegate and charge pipe. you go to any autoparts store and get the 3 bar map sensor from GM.. just ask for one from a grand national its like 30 bucks max i believe. then you send the boost control kit in with the map sensor. they will calibrate it for free. then off you go. 3 bar map...
thats all i have. pm me if you want to make the trade.
bck retails for about 300.00. fyi.. if not more.
this is a must have part for anyone running the power fc.
pm! if u have questions
no it doesent come with the apexi map sensor. i have 2 boost control kits. neither of them came with the map sensor. i have always used the gm 3 bar. its much more receptive and reliable. its a great deal because i sold many 1jz soarer ecu's for 50 to 70 bucks on ebay so honestly the trade is more of an opportunity for someone with an ecu lying around.
Biggu
SC400 / 300 Classifieds
14
01-10-12 06:05 AM
