MS FS: 1uz-fe SC400 parts: engine, oil pan, manifolds
Email: gixxer750ms@hotmail.com - goes straight to my blackberry, so I get it anytime.
Phone: 601-754-2444 cell(call, text, MMS) after 5 central time: Work: 601-833-6085 - please do not call unless you feel absolutely necessary, I stay pretty busy at work. I'm a productive person.
Other Forums I'm on under the same user ID: Supramania/club NA-T/Supraforums(gixxer750ms)/www.nostreetracing.org(new orleans forums: slowsupra), gixxer.com :04gixxer750blue I have bought and sold items on these forums. I did have an incident on SM a few years ago, but it was resolved when I eventually found out about it. I stopped frequenting there when I sold my MKIII and got my MKIV
Complete 1uz-fe Rear/center sump SC400 oil pan. Comes with pickup tube, upper and lower pans, oil level sensor, baffles, bolts, and the oil drain plug. The lower pan is not dented up. $ 175 + shipping
![](http://i214.photobucket.com/albums/cc124/gixxer750ms/COD/IMG00057-20100510-2122.jpg)
1uz-fe longblock - no oil pan. Comes with valve covers, heads, block, internals. No accessories, no intake manifold, no exhaust manifold. This engine needs rebuilt. I pressure washed it, got a little water in number 1 and got a little rust on cylinder wall. It is not seized, and was running three days ago when I finished my swap. It smokes and misses. Oils down #1 spark plug in about 5 minutes and has around 40 psi on #1 cylinder. Rest of the cylinders do fine. $200 + shipping. All the parts listed are still in assembled form. Does not have any form of rod knock, and had good oil pressure, so I'm sure the crank is fine.
Engine will also come with cams/cam gears/timing belt/good water pump and in time still. It had 98124 miles out of the car I pulled it from that was wrecked. Good block for someone to build, or maybe a mockup block.
![](http://i214.photobucket.com/albums/cc124/gixxer750ms/COD/IMG00056-20100510-2054.jpg)
SC400 exhaust manifolds - one complete, 2 cut ones. Come with good 02 sensors in two of them. $ 50 + shipping
![](http://i214.photobucket.com/albums/cc124/gixxer750ms/COD/IMG00058-20100510-2125.jpg)
1uz-fe upper and lower intake manifolds - comes with rails and injectors, non trac throttle body with TPS also. $75
![](http://i214.photobucket.com/albums/cc124/gixxer750ms/COD/IMG00052-20100509-1601.jpg)
