FL GE motor, cruise control, BL 2.5 MM HG, w58 5 speed, v8 maf
All items are located in orlando, willing to ship everything but the motor unless its broken down ( will not ship block, unless you can arrange ) also not shipping trans
GE Motor with 150k, definitely needs a rebuild as it was smoking when it was pulled and the pistons show lots of signs of detonation.
Willing to part if there is enough interest, looking to get 300.
Boost Logic 2.5 MM head gasket. Has about 20k on it, looks fine.. looking for 150+ shipping OBO
NA PS Res, touched the battery at one point and doesnt look so pretty. 30+ shipping
GE oil pump, motor had 80k on it. Only removed because it was rebuilt with all brand new stuff.
50 + shipping
NA Cruise control unit ( not sure if it varies from TT, manifolds are different so probably). Worked fine, removed because of front facing intake.
80 + shipping.
Also have other stuff available that I forget to post if you can think of anything you need off the GE motor.. extra valve covers, water pump, etc
w58 tranny, ran perfect, shifts super smooth (was running redline oil), no problems at all just upgraded my setup and am afraid to put it back in there with bigger turbo 350$
Also have the flywheel, no idea what its worth
NA intake manifold lower runners, perfect to use for making a custom FFIM 75$
Lexus V8 Maf, with filter adapter housing 65$
50 + shipping
80 + shipping.
bobmarley
SC400 / 300 Classifieds
09-10-10 12:51 PM
onejapman
11-10-09 06:09 AM
