NC FS: 1JZ CUSCO hyper Single Clutch/Flywheel *Ultra Deal*
After Finally finding the replacement Disc for this Clutch System (called exedy and don't speak japanese to call CUSCO) I had already gone a diff route.
This is for the Pressure plate,lightweight Flywheel (machinable) and the hardware to mount it up.
This system New is $1300.
Smaller disc and for lower Inertia=excellent Rev lower mass.
![](http://img.photobucket.com/albums/v703/Mrfairlady/IMG_1530.jpg)
![](http://img.photobucket.com/albums/v703/Mrfairlady/IMG_1531.jpg)
![](http://img.photobucket.com/albums/v703/Mrfairlady/IMG_1533.jpg)
Here is the replacement Disc that You will need since The one I have is Burned up.
http://www.rhdjapan.com/cusco-single...sc-honda-60341
This Clutch kit came on my Soarer 1JZ and would have loved to use it but Didn't find the disc till now - after speaking with RHDjapan.
$400 shipped - all you need to get is the disc and maybe a new Bearing
I'm looking to replace my clutch and flywheel in my Soarer pretty soon, but not quite sure what I would need with this? I want to change everything including the Pilot bearing etc etc
You need what I have here + a new pilot ($12) and throwout bearing ($30).
machine the Flywheel and Drop it in. $1300 clutch for super cheap.Flywheel is Lightweight and Still STEEL.
I know some Chromoloy Flywheels you can't resurface.Turns out this one is Steel.
