TX Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts
Old 05-16-10, 11:33 PM
lev00221
lev00221's Avatar
Default Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles
Hello,
I am the very fortunate owner of Streetking's (a.k.a. SW of fastest Supra fame; very well known in the 2Jz and auto community) extremely low mileage SC300. I purchased it in 2/09 and have since made some changes to make it more to my taste. Among these changes was a 5spd swap done by Chris Johnson of Performance Motorsports. Thus, I am selling the built automatic transmission and torque converter with about 2500 miles of use. Streetking bought the car with 5700 miles back in 2006. He had all the work done at Boost logic and then pretty much garaged the car. I purchased it from him with 6945 miles in 2/09. I had the swap done in 12/09. My odometer now reads 8725 (see picture) but I only drive the car occasionally as I don't use it as my daily driver.
The transmission and torque converter drive as if they were new. The car was tuned to shift firmly and quickly. No slipping whatsoever. It made the car very fast when on boost as the shifts were instantaneous. As fun as it was to drive the car like that I much prefer shifting my own gears. Hence, the swap to a 5spd manual. Boostlogic does not list this tranny on there website but does show the built tranny for the NA Supra which I believe is the same. The website specifies that the transimission is designed to 550 rwhp and the torque converter is upgraded to a 2800 rpm stall. The price for both new is $2350 plus shipping.
Boostlogic Built transimission and upgraded Torque converter
$1350.00 plus shipping.
This transmission is different from the TT Auto tranny that can hold more horsepower and can be controlled by the GTE ecu.
VERY IMPORTANT:
THIS TRANSMISSION WILL WORK ON 92-97 SC300 (NON VVTi) AND NA SUPRA MKIV (NON VVTi). IT WILL BOLT UP TO A GTE MOTOR BUT IS NOT COMPATIBLE WITH THE STOCK TT ECU. THAT IS, THE ECU CANNOT RUN THIS TRANSMISSION. IT SHOULD ALSO WORK WITH NON VVTi GS300.
I am an honest seller and have extensive feedback on eBay under lev00221. I have also had dealings with several members of the Clublexus community.
More pictures on next post.
Attached Thumbnails Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-engineshot.jpg   Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-salesreceipt.jpg   Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-mileagedisclosure.jpg   Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-odometer.jpg   Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-tranny1.jpg
lev00221 is offline
Old 05-16-10, 11:36 PM
lev00221
lev00221's Avatar
Default More Tranny Pictures
Tranny and torque converter
Other items moved to new thread.
Attached Thumbnails Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-tranny.jpg   Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts-torqueconverter.jpg
lev00221 is offline
Old 05-17-10, 06:51 AM
lisc300
lisc300's Avatar
would my existing sc drive shaft work with this tranny...Im looking for the tranny to handle a bit more horsepower is that possible..ZFinally can i run a gte bottom end with this tranny
lisc300 is offline
Old 05-17-10, 07:13 AM
lev00221
lev00221's Avatar
If you have an automatic SC then your drive shaft will work perfectly. As far as the GTE bottom end I am not 100% sure. I would think that you can since the Getrag can bolt up to your car and to mine as well without modifications. Surely, someone else on this forum can answer that easily.
Thank you for your interest.
Luis
lev00221 is offline
Old 05-17-10, 07:17 AM
lev00221
lev00221's Avatar
Default Pictures of LS Wheel
Moved to wheels section.
lev00221 is offline
Old 05-17-10, 09:37 AM
lisc300
lisc300's Avatar
Did you have any problems with the gearing on the factory diff when you were running boost
lisc300 is offline
Old 05-17-10, 07:23 PM
lev00221
lev00221's Avatar
No problems whatsoever. The car felt really fast and smooth. I did have issues with it not being LSD but I had the TRD LSD installed with the 5spd swap.
lev00221 is offline
Old 05-18-10, 11:36 AM
lisc300
lisc300's Avatar
how much would it be to ship to 11735...would it efect my VVti at all
lisc300 is offline
Old 05-18-10, 04:22 PM
lev00221
lev00221's Avatar
Let me check on a shipping quote. The VVti should not be affected. As far as an ECU I am not sure what would be needed.
lev00221 is offline
Old 05-19-10, 09:06 AM
lisc300
lisc300's Avatar
can this be run with the factory ecu for the time being
lisc300 is offline
Old 05-19-10, 02:01 PM
S14eva1
S14eva1's Avatar
I believe the vvti auto trans may be different.....cant remember,but it shood be a 5spd auto....this is a 4spd auto.Im not %100 but look into it
good price,good luck
S14eva1 is offline
Old 05-19-10, 02:23 PM
lev00221
lev00221's Avatar
I was wrong. 2JZ with VVTi will NOT work with original ECU. I am not sure about piggyback ECU. This tranny will work with 92-96 SC300 and SC400 NON VVTi only if you are using stock ECU. I believe that it will work in 93-98 Supra NA-T since it has the same drivetrain as my car.
I apologize if I misled you.
Thanks,
Luis
lev00221 is offline
Old 05-20-10, 07:48 AM
S14eva1
S14eva1's Avatar
Correction.....It will also work on a 97 SC,like the car it was just taken out from
VVTI models are 98-up
S14eva1 is offline
Old 05-20-10, 08:41 AM
lev00221
lev00221's Avatar
Yes, forgive my mistake. SC's from 1992 - 1997 NON VVTi.
lev00221 is offline
Old 05-21-10, 03:01 PM
lev00221
lev00221's Avatar
Anyone interested in a great tranny that is nearly new?
lev00221 is offline
Quick Reply: TX Boost Logic Built Tranny and Torque Converter SC300 with 3000 miles, other parts
