TN FS: Haltech Platinum Sport 2000 (NA-T plug-n-play)
Hey guys,
I am selling my haltech PS2000 EMS complete with intake air temp sensor, internal 2.5bar map sensor (22psi), configured to use stock 2jzGE coolant temp sensor. retail is over 1700$ new (with a flying lead harness)
also included is the haltech dual channel wideband o2 sensor w/ 1 sensor (can add another o2 sensor if you want)
FULL PLUG AND PLAY HARNESS TO RUN your 2JZGE w/ DISTRIBUTOR
the only wiring you'll have to do is connect the tacho wire from the haltech to the plug in the passenger kick panel area (i even have it labeled)
this can easily be configured to run the 2jzGTE stock igniter/coils. i could even set it up for you!
the haltech is running sequential injection with 460cc rx7 injectors (yeah, they fit the GE fuel rail), and is capable of running direct fire ignition for 6cyl (i just decided to use the distributor for the time being for simplicity). I can include my rx7 injectors as well.
this is the top of the line haltech EMS (excluding the GTR and 350z platinum pro ECUs) that retails for over $1700, plus a 250$ wideband o2
HALTECH ALSO SELLS A FULL PLUG-N-PLAY HARNESS FOR A SUPRA 2JZGTE if you dont feel like changing anything with the 2jzGE harness (this would plug into the stock supra GTE harness just like the AEM) you'd still come out spending less money than a new one (and you'll have a haltech wideband with it!) http://www.haltechparts.com/Sport-20...al%2034500.htm
I also have this tuned perfectly on gasoline and E85 with two maps i'll include.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
![](https://hphotos-snc3.fbcdn.net/hs578.snc3/31520_681353285802_41107033_38689440_6206009_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs538.ash1/31520_681353325722_41107033_38689447_7736091_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs538.ash1/31520_681353305762_41107033_38689443_1986234_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs538.ash1/31520_681353315742_41107033_38689445_7200669_n.jpg)
![](https://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs538.ash1/31520_681353320732_41107033_38689446_1323685_n.jpg)
price is 1600 shipped!
