NC WTB: 1JZ cut compressor lines (R12 compressor)
Well...If anyone has any cut A/c lower soft lines coming off the compressors manifold I need them.
Need the ends to make new custom lines to match my SC400 body lines.
**as long as you can shoot me pic's and there is the Full Metal Coupler attached I can use them.
I really only need 1 line & its the line on the left side of the compressor..not the right side with the Crazy upside down "L" shape coming off the compressor.
please hook me up.
please hook me up.
Certain Sc300 lines do not match the 1JZ compressor "Manifold", unless for some reason the R12 SC300 lines are diff than the ones I have.maybe I have R134 lines? I'll figure that out.
*Either way they are too short so they won't work (has to be custom the way a SC400 is) so what I'm trying to do is Find someone with cut 1JZ lines for cheap so i can Use the metal Ends and then have them re-crimped onto new lines w/ my SC400 lines for the body side.
R12 fittings have larger holes than the oem R134a fittings.
I have an 92-94 Soarer R12 compressor and only 1 line.
http://img.villagephotos.com/p/2003-...2/DSC00153.JPG
Ryan,.Sucks the one you have is the one I already have that I need to use,...need the one right next to it and I can get this done/made up for me.
Sucks.Gonna try to see if the SC300 R12 lines are the same as the 1JZ's.Someone is working on that for me.
thanks though.
