FL Budget Build Tuner's Special: GTE head, intake, turbos, oil lines,
Here's one for you budget build 2jz tinkerers. Most (not all obviously) of the parts to drop a GTE head on a GE block. I ran this set up for a while and it made plenty power.
This is a concise list of the components:
2JZGTE head (low mileage jdm w/ cams)
JDM Twin Turbos w/ cast piping
Valve Covers (not pictures but included)
GTE Intake Manifold with upper plenum (no TB)
GTE fuel rail
Custom metal oil lines to pull from GE oil filter boss to twins and return to GTE pan
GTE upper pan (with oil return)
REAL greddy type S BOV
For all this asking $650 picked up. Will help deliver around central florida area w/ my truck.
![](https://img706.imageshack.us/img706/6753/img3363x.jpg)
Also available but not included in the above price:
2x GTE coil packs
6x GTE pistons/rods
Used GTE head gasket 400 miles (removed to bore .20)
USDM GTE Cams
USDM GTE turbos
GTE MAS
GTE fuel rail
2x GTE coil packs
6x GTE pistons/rods
USDM GTE Cams
USDM GTE turbos
GTE MAS
