MD FS: 1jz/2jz block, head, 1JZ stock twins, HKS Fcon, 5speed swap, MUCH MORE!
Phone: 443-786-5205
Email: cpkeller@goeaston.net
I prefer to be contacted via phone or pm instead of email because I have a problem with outgoing. Texting is fine too.
I understand I don't have a lot of posts here but I've been here and on Supraforums for awhile and I've bought a lot from other members. This is my first for sale thread. I prefer not to deal with shipping. So local pickup as of right now is the only option. I'm trying to raise a little bit of money by next Wednesday, working on a deadline. So most of these deals will be gone after then.
Cash is king, I can deliver to within a reasonable distance or meet halfway, with larger items I don't have a truck so it would be hard for me to deliver them. I don't want to ship and I want to use paypal even less.
Pictures will be posted as soon as I get around to taking them.
More detailed pictures will be taken by request.
ALL parts are from an SC300 or Soarer unless otherwise noted.
Now on to the parts:
Sold 1JZ-GTE Longblock, mostly disassembled. Rear sump, 100% factory, comes with cams, valve covers(sanded down to be repainted or polished), and most accessory pumps, PS/WP/Alt. Brand new water pump installed at well as timing belt. A/C Compressor sold
Sold 2JZ-GE Shortblock 160k miles, great condition, good for 1.5JZ build. Comes with rear sump pan, and all accessories/pumps. As well as brand new timing belt, not installed.
$20 1.5JZ water pump pipe, same as on driftmotion. Brand new with o-rings
Sold 1JZ-GTE stock twins, freshest set I have ever seen. 0 shaft play, none, nada, feels like brand new turbos.
$75 Charge pipes and manifolds for stock 1JZ twins, good condition.
Sold 2JZ-GE Head, comes with cams, good shape.
Sold 2JZ-GE intake manifold, nothing special
Sold 1JZ-GTE Soarer Intake Manifold, upper and lower runners, with TB
Sold 2JZ-GE wiring harness, 95 SC300, two cut body plugs, what was cut off will be included, maybe 10 wires in total need to be re soldered
Sold 1JZ-GTE 1991 Soarer wiring harness, all but one or two body plugs extended. otherwise great shape
Sold 1JZ-GTE coilpacks, they've been sitting for awhile. I've never used them so I'm unsure of condition.
Sold Soarer SMIC, with all piping and clamps.
Pending HKS Fcon V-pro w/jumper harness for Soarer non vvti, unsure of what tune is on there.
Sold high flow fuel rail, HKS copy, chromed, fits bosche style injectors. comes with fittings and mounting screws.
$250 Evo 8 Enkei wheels, 17x8, 5x114.3 bolt pattern, rattle can black, needs a fresh coat of paint or whatever you want to do with them. No tires.
Sold 1JZ-GTE gasket kit, purchased from driftmotion, includes headgasket.
$200 Soarer Automatic 1JZ-GTE ECU, verified works flawlessly.
That's it for now. More may be added later. If you don't like a price then let me know but please no bickering in this thread. Lowballers will be ignored.
EDIT: I will now be shipping items that can fit in flat rate boxes, shipping is in addition to prices listed.
Phone: 443-786-5205
oh well im not really interested in the 2jzge harness....
i need a plug and play 1jz soarer harness that will go right into the sc300 (with 1jz of course).
let me make sure i have everything else i need...
All you need to do is extend two more body plugs for the 1JZ harness. I'm not exactly sure what they are for. I can take pictures for you though. Otherwise it is plug and play for OBD1 SC300s, if there's anything else you need for the swap I have a garage full of parts for sale, not just what is listed here so I probably have it.
