CA WTB: cheap sc300 o2 sensor (x2)
needs to be compatible with my 92 sc300. needs to be single wire, with connector. ideally I ONLY NEED THE WIRES &CONNECTORS.
so you can cut the sensor off, but give me the entire wire, so the sensor would not even have a stem of wire on it.
people with bad o2 sensors, this is your chance to make money off it. i need the two of them, pre cat o2 sensors, on the 2jzge manifold, looking to spend no more then 25 bucks shipped for just wires &connectors.
picture only shows example of what i need, no o2 sensor, but cut the wire at the line.
![](http://i758.photobucket.com/albums/xx224/fenderub/128129441347241.gif)
i have both from my 93 sc.
$15. come pick them up in ontario if you need it asap
email is tiraceteam@turboimport.com
