CA FS: one of a kind NA-T kit! 95% complete!
its more like 10-15% incomplete now since part of it has been parted out, but the listing on the OP has been updated to what you will get.
to get this kit essentially running, you will need a boost controller, boost gauge tubing, IC piping, hose to go from the PVC outlet to the intake of the turbo, oil return hose [would recommend silicone] universal o2 sensors, two that screw into the manifold. the o2 sensor you could use is part number: 11027 bosch o2 sensors, you just need 2.
now if you wanted to squeeze everything out of it, i would suggest tunning, you can use the greddy emanage with the kit, or a safc2, either will be fine. a wideband would be strongly encouraged for tuning.
heres some pics:
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4409.jpg)
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4407.jpg)
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4412.jpg)
heres some pics:
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4413.jpg)
