FL GE motor/parts, BL 2.5 MM HG, W58 clutch slave, engine stand, valve compressor,filter
All items are located in orlando, willing to ship everything but the motor unless its broken down ( will not ship block, unless you can arrange )
GE Motor with 150k, definitely needs a rebuild as it was smoking when it was pulled and the pistons show lots of signs of detonation. Head is just sitting on block because I pulled the ARP studs that were in there and the BL HG. Some sensors removed, along with motor mounts etc.
Willing to part if there is enough interest, looking to get 200.
W58 Clutch slave 35$ (5 miles on it, literally,swapped to r154)
Boost Logic 2.5 MM head gasket. Has about 20k on it, looks fine.. looking for 100+ shipping OBO
NA PS Res, touched the battery at one point and doesnt look so pretty. 20+ shipping
GE oil pump, motor had 80k on it. Only removed because it was rebuilt with all brand new stuff.
50 + shipping
NA Cruise control unit ( not sure if it varies from TT, manifolds are different so probably). Worked fine, removed because of front facing intake.
80 + shipping.
more parts gotta go
Engine stand, got from my builder new with the motor when he finished the bottom end, brought into my living room to finish and now its for sale.. looks brand new, 50$+ shipping
K & N 3.5" air filter 30$, was freshly cleaned and oiled
Valve spring compressor, bought from summit, worked great on the supra, dont need anymore 35$
Stock 5 Speed supra ECU, 50$
Bosch 02 sensor wired into to two harnesses for downpipe, 25$
Stock intake piping/box 10$ plus shipping
sceptre air filter 15$ plus shipping
Y pipe, throttle body, intake plenum (pollished but have been sitting and are dirty) 65$ obo will part out
Intake runners 40$
Also have other stuff available that I forget to post if you can think of anything you need off the GE motor.. extra valve covers, water pump, etc
50 + shipping
80 + shipping.
more parts gotta go
Intake runners 40$
sicksupra1
SC400 / 300 Classifieds
02-04-08 05:55 PM
