MD FS:1999 SC4 Gated Shifter
For Sale 1999 Gated Shifter, to include shift linkage, and Pigtail wire connectors. Wood shifter **** has been sold, it has a gray shifter **** from a GS currently.I will include also the shifter bezel(w/o Heated seat switches), and wood ashtray $200 shipped ![](http://home.comcast.net/~balconnelly/pwpimages/DSCF0409.JPG?PHPSESSID=7c58c0e90f7fca870591bbe7dbf4aa05)
I also have just the gated shifter from another 1999 SC400, no ****, no shifter bezel, no wood ash tray, sold just as pictured the Shifter, and the linkage. $125 Shipped
![](http://home.comcast.net/~balconnelly/pwpimages/DSCF0520.JPG)
Last edited by BALConnell; 12-10-10 at 10:52 AM. Reason: added more parts for sale, lowered pricing
Emilio,
The shifter will fit any year SC Lexus 300 or 400. But if you want all the trim panels to work, you will need the shifter surround/bezel, it is not the same as the older. The wood ash tray is a nice touch.
As far as the connections, I do not have the pigtails that plug into the shifter, but that can be hard wired, many have done this mod on the forums. Wiring diagram is available with a quick search.
E,
Let me see if i can find one, the shifter bezel is plastic, it only looks wood, so you could notch out an opening for your current switches, or just relocate the current switches you have to a close by location, the switch will remove from your curtrent shifter bezel.
Regards
Bart
Regards
Bart
that would be cool if you could do that.. and what about the overdrive button on the current 92 shifter? would the overdrive always be off.. and the trac light would be off too wouldn't it? since it doesn't have a traction button either
