TX W58 swap almost complete for Sc300
I'd like to pass along this setup to someone here to use. I think the clutch is going to be very nice once broken in.
If you need vouches let me know. I've sold quite a bit of stuff through here already with no issues and good feedback here and at Supraforums where moderator Zazzn can vouch for me.
I'm selling my Sc300/Mkiv Supra W58 5 speed swap parts. This is the W58 with the cradle shifter extension housing.
This fits ALL Mkiv Supras and 1995-1997 Lexus Sc300s as a direct fit. If your doing a auto to 5spd swap, you can make this fit any year Lexus Sc300/Sc400.
Parts list-
1. Mkiv Supra W58 transmission**just rebuilt to new specs by the best, 35yrs experience in manual transmissions**
2. Sc300 OEM stock 5 speed driveshaft Excellent condition(VERY hard to find), includes rubber dampner- DONUT**
3. Stock shifter***Also have TRD shortshifter instead for full asking price
4. Competition Clutch Stage 4 (NEW) has sprung hub disc with pucks. This is rated at 500hp, so the trans will break before this clutch kit does.
Here's info, pretty bold statement "250% increase in torque capacity"
http://thmotorsports.com/competition.../i-152562.aspx
5. New OEM Slave cylinder
6. New OEM Flywheel/Pressure plate bolts<---This is $50+ at COST btw
7. New OEM throwout bearing/pilot bearing
8. Clutch fork
9. trans mount
10. Supra/Sc300 manual crossmember
11. Fidanza Flywheel
Now that the trans has been gone through, you should have no worries about it lasting longer than the car.
$1700+shipping for everything listed. We can talk about shipping, I've done it MANY times in the past.
![](http://img.villagephotos.com/p/2003-5/202062/SVTKY-DSC01271.JPG)
![](http://img.villagephotos.com/p/2003-5/202062/CUREY-DSC01273.JPG)
The input shaft has even been polished, it will slide right on in, if you leave it in gear and have the driveshaft in the back so you can spin the DS
![](http://img.villagephotos.com/p/2003-5/202062/GWPCI-DSC01270.JPG)
Has speed sensor and reverse switch
![](http://img.villagephotos.com/p/2003-5/202062/UUAEB-DSC01269.JPG)
Parts list-
8. Clutch fork
9. trans mount
I just had the transmission overhauled by the best manual trans guy in Austin. He's the guy that transmission shops take their **** to when they can't fix it correctly.
It's new now, price adjusted, but I'll probably just use this setup..unless a serious offer hits the table.
I just bought a used Fidanza with 2k miles on it so that would be included as well.
