FL FS: Driftmotion lightweight (11.5lb) Flywheel & Clutch Combo
I had this installed in my car for less than 30 miles. Will work with a 1JZ or Any 2JZ with an R154 trans attached.
Its a like new drift motion 1jz 11.5lb flywheel and a ceramic 4 puck unsprung disc. The stock pressure plate I reused is bad, so you will need one of your own.
I ran the 4puck unspung with an OEM 1JZ pressure plate for 2 years and up to 700whp with no problems.....probably 40 passes down the track too. I changed to a Spec Twin Disc (for better or for worse
$450 picked up.
$450 picked up.
bump
I also have a regular 1jz flywheel. It's got some surface rust from sitting in a box in the garage. As soon as you touch it with the clutch it'll clean it right off....no biggie.
