TX omplete NA-t engine with turbo kit, IC, piping, harness, AEM sensors, DLI, injectors
Lexus 2JZ-GE with less than 45K miles
toyota twin turbo head gasket stacked (2)
arp head studs
engine harness 95 SC300 5-speed, ready for AEM ECU hook-up
HKS DLI
AEM 3.5 bar map sensor
AEM air temp sensor
BL NA-t turbo kit w/ intercooler and piping w/ HKS BOV
RCI injectors (not sure what size)
modified stock fuel rail for dual input
precision turbo T-67
custom recirculated wastegate
Basically you could install this engine and components and be at 600+rwhp on race gas, or 450+rwhp on 93 pump
not included, you will have to run dual walbor pumps in the tank with upgraded fuel lines and external fuel pressure regulator. It is setup for a AEM ECU, 1101 or 1100
This is the engine that came out of my personal SC that I have had for 6-7 years, the only reason it was pulled was to R & D a compound turbo kit for GTE fitment.
I want $4500 for the above, which less than a BL stage 2 kit
email-chrisatpm@aol.com
![](https://www.fototime.com/6435FB0C5F8A468/standard.jpg)
![](https://www.fototime.com/F2DB4CE2189C566/standard.jpg)
![](https://www.fototime.com/958CE986FF38822/standard.jpg)
![](https://www.fototime.com/76D5B3B065F4F5A/standard.jpg)
![](https://www.fototime.com/4EB232C11A18233/standard.jpg)
setup in the car
arp head studs
HKS DLI
AEM air temp sensor
setup in the car
![](https://www.fototime.com/D63E0308E2D6853/standard.jpg)
High PSI
SC400 / 300 Classifieds
19
05-17-13 07:29 PM
PM Supra
01-16-12 08:14 PM
