NC Adaptronic to SC400 wire loom.
Wired this for my car but have made a new custom loom for my new motor, elimated the ECU plugs all together.
This was wired for my setup on my 95 SC400. This may need some re-wiring depending on you setup of course. It's a bit long but will fit under the stock ECU cover.
The ECU side connector is the same as the SC400 and I think Supras as well that use the 40-40-40 connector.
$100 and I'm pretty firm at this point.
I can also send you an Excel file with a pretty much complete diagram of the harness.
Thanks for looking.
KC
Thanks for looking.
KC
Taking a quick look at the wiring diagram it looks like the ECU connector is the same. 1 40 pin connector and 1 80 pin connector. So, you could wire it anyway you want.
You would have to do some wiring though. Most obvious is the injector wiring. My 95 is batch fire injection (4 pair of injector outputs) versus the 97 is full sequential injection (8 seperate outputs).
With most aftermarket ECU options you'll have to pair injectors anyway cause most don't have 8 outputs.
I need to make it clear that although this harness is mostly PnP with 95 (96?) and lower years and should at least plug into higher years, some wiring WILL BE NEEDED to suit the needs of the user / buyer. If I was buying this harness like it is from someone I would go over every wire and make sure everything is where it needs to be.
Also, I can supply factory wiring diagrams if needed and a wiring diagram of this harness.
Thanks,
KC
Thanks,
KC
RedPhoenix
Florida Lexus Club
12-22-09 02:37 PM
