GA FS: Adjustable FCA's & RCA's
thanks in advance
but i would also like to know if they will fit the sc without modifications of some sort if possible
Correct.
I honestly do not have the answer to that question. I bought them under the impression they would bolt up directly. I'm 99% sure they do. My understanding is that we can buy Supra control arms and they bolt right up.
Update: If you dig deep enough you'll always find what you're looking for on this forum.
THE FRONTS WILL BOLT UP WITHOUT MODIFICATION.
It turns out you'll have to shave about a 16th of an inch off the chassis mount to fit these in the rear.
interesting, good info. thanks for doing the pita searching for us hahah. I may be picking up a pair of these down the line then since tcsportline seem to be super local. as long as the modding is limited to simple stuff like shaving it down a couple mm, it shouldn't be too big of a problem for anyone.
may be a stupid question, but im guessing these are for camber adjustments, not too familiar with these. if so they do camber how much negative/positive can these bad boys do. if they do...
