AL SC400 motor part out
1JZ Single SC400
I have a torn apart a running motor out of my 1993 SC400. I have decided to just sell the parts off of it, than the whole thing. I was going to build it, but do to the money/cost to build it, I will just install a 2JZGTE, non vvti motor with a W58 or a R154. These parts will go cheap.. If you need something in particular, post and I will respond.
These are the things I have for sale
-block $125
-heads with valves, springs, shims, still installed with head bolts. $60 each
-fuel rails $25 each
-all 8 injectors, the gaskets appear to be in good shape $80 all eight
-intake manifold $60
-throttle body with cruise control cable and motor still attached $60
-all four cams $100
-tps sensor $30
-trac sensor $30
-fuel lines $20 each
-both headers, good for a turbo setup, just turn around $25 each
-both cats, non clogged with all four 02 sensors, in really good shape, $150
-EGR system complete with vacuum lines $15
-full exhaust, Magnaflow center cat $50
-valve covers $25 each
-PCV valve with hose $5
-cam gears $20 both
-harmonic balancer pulley $25
-intake tubing into the throttle body $25
-plastic plug covers and for the distrubutors $25 Each
-all the screws and bolts
-full complete transmission with all the sensors, dipstick and wiring $150
-ECU main $80
-Full wiring harness $80
-all sensors on block
-starter $75
-starter housing with bolts, including if buy the starter, seperate $15
much much more
Make me an offer.. All these items will come with the screws or bolts. Will ship out same day or next day with tracking. If you need something and its not listed , just ask! text or call me at 205-482-5533. I also have lots of pictures, available upon request.
Prices are without shipping.. Moderators I have added prices. Sorry!
-block $125
-all four cams $100
-tps sensor $30
-trac sensor $30
-cam gears $20 both
-ECU main $80
-starter $75
much much more
1JZ Single SC400
The block I will sell for $125 plus shipping.. It will inlcude the oil pan, rings, pistons, etc.. Its heavy, I dont know about shipping. LMK
