CA FS: 2JZGE, GT3071r NA-T kit
this nearly complete - one of a kind kit is up for grabs!
the heat-shield is already modified to fit the dizzy with no issue, same with dp, made to fit the sc specifically but im sure it can fit other cars aswell.
i have put in many hours fabricating and getting things to fit the 2jzge just right. a bunch of headaches has also already been dealt with so installation is a piece of cake for the buyer!!! for who ever buys, i can walk you through installation and answer any other questions you may want to ask.
This kit will spool quick, good for about 350-450whp
kit includes:
Garrett Aust. GT3071R .50 a/r coldside, .86 a/r hotside, some shaft play, but doesnt hit the housings. polished housing
AVO Aust NiResist Cast iron manifold
wastegate actuator
manifold & DP heat shield
XS Engineering fmic, 3" in/out 34"x11"x3"
GReddy Emanage Blue with both injection and timing harness
custom DP with x2 o2 bungs and caps
oil return fitting for your upper oil pan.
water lines, in and out
intake pipe with fitting to the #2 PCV valve
is300 union bolt with gasket, brand new
ss oil feed line -4 an female to a 1/8 npt male
t25 gasket already installed, 5bolt gasket for turbo to DP included.
manifold to head gasket
waste gate pressure fitting
turbo bolts and nuts also included
this kit is well worth over $4000, asking 2000 shipped OBO. need this to be moved fast!
![](http://i758.photobucket.com/albums/xx224/fenderub/DSC_4422.jpg)
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4607.jpg)
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4608.jpg)
kit includes:
wastegate actuator
![](http://i758.photobucket.com/albums/xx224/fenderub/IMG_4606.jpg)
