CA FS: Springs and Amp
FS: Springs and Amp
Hello,
I am in City Of Industry area and all sales kept local only. PM me if you are interested.
I have for sale stock OEM Springs and rubber boots off of my 1997 SC400. Worked perfect nothing wrong asking $50.
Also for sale US Amps/RE Audio AMP XT800.2 V3 brand new never used only opened to look at. Asking $65.
Specs for Amp:
Features:
XT800.2 V3 400 watt RMS (800w peak) 2 channel bridgeable car amplifier
800 watts peak output
200w x 2 RMS @ 2 Ohms
400w x 1 RMS @ 4 ohms
100w x 2 RMS @ 4 ohms
Bridgeable
Efficiency: 70 % @ 4 Ohms or 65 % @ 2 Ohms
Fully adjustable butterworth high and low pass crossover filters
High pass filter - adjustable 40 HZ - 1 KHZ @ 12 dB per octave
Low Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octave
Adjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZ
Subsonic Filter: 15-40 HZ @ 24 dB per octave
Low level Input
RCA Pre-amp output
Block Power Connector
Requires true 8 gauge power wire for installation
Screw terminal barrier strip speaker connectors
8 - 18 AWG speaker connector gauge
Aluminum heatsink
Convention cooling
power and protection LED Indicators
Class A/B
Frequency Response: 5 HZ - 50 KHZ
Weight: 7 pounds
Dimensions: 1.875" x 10" x 9.75"
I will post pics up later tonight. Thanks for looking.
Specs for Amp:
Features:
Bridgeable
Low level Input
RCA Pre-amp output
Aluminum heatsink
Convention cooling
Class A/B
Weight: 7 pounds
Allenchang
06-27-06 03:09 PM
livesc400
06-15-04 10:17 AM
livesc400
04-19-04 07:34 PM
