OH FS: Soarer 1jz/r154 drop out, Recaro seats, Greddy Ti + more
So to put it lightly Ive got some stuff to sell.
First and for most, No trades and DO NOT LOWBALL ME. The prices are very fair for what your getting.....
First things first, REAL soarer 1jz with a Soarer r154. Came out of a 1995 Soarer and came in the form of a half cut so everything is there. Comes with everything to drop into a 5 speed SC300 nothing else will be needed except an intercooler which you can buy here as well. Engine has exact miles unknown but it should be 55-60k. Timing belt, water pump was just replaced 2 months ago. Waterpump is toyota OEM, with OEM timing belt.
I do not want to split this up, the only things I will split up are the ECU package.
Soarer 1jz
Soarer r154
C's Short shifter (RARE!)
Soarer 2 piece drive shaft
XTD clutch and pressure plate
Toyota OEM Water Pump
Toyota OEM Tensioner
Toyota OEM Ideler pully
Toyota OEM Crank bolt
Toyota timing belt
Wiring harness is extended for a LHD car
comes with Ignitor, OEM Map sensor and SOARER powersteering res
In the pictures its single turbo format, Stock twins are going back on
but Im asking $2800 for everything there. Price isnt for everyone but its EXTREMELY fair for a complete drop in setup that is already got all the maintenance done. The engine is clean as can be and there is no gunk/sludge inside.
http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0935.jpg[/img]
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0936.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0937.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0808.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0900.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0903.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0907.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0908.jpg)
![](http://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0909.jpg)
HKS 2jz/1jz Cam gears, 1000 miles MAX
$250
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0841.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0896.jpg)
HKS Timing belt, 1000 miles MAX
$150
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0827.jpg)
Greddy Clear timing cover 1jz Some marking in the plastic but still looks good
$200 or $150 with your stock cover (in good condition)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0826.jpg)
Greddy 60mm boost gauge with the data link unit.
awesome gauge, just dont have use for it. 2 Bar gauge has the warning and remember functions
$150
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0914.jpg)
RJS Latch type harness kits in Purple, Have two of them both SFI approved
$50 each
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0901.jpg)
AEM Uego, unknown miles, one wire in the harness isnt all the way in however its a signal output so no big deal. Worked well in the car.
$125
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0916.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0917.jpg)
Greddy Trust shift **** 5 speed
$50
Soarer 1jz
Soarer r154
Toyota timing belt
$250
$150
$150
$50 each
$125
$50
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0922.jpg)
GT40 Single turbo kit for 1jz includes:
Precision GT4067 w/ .68AR exhaust housing, 4" v-band exit, and 4" inlet
Drewgo T4 exhaust manifold
Oil feed lines and fittings
Oil drain lines and fittings
Tial 44mm Gate Purple
Screamer pipe
3' downpipe with flex section in it and heat wrapped (4" vband flange)
HKS Intake filter and intake pipe
There is absolutly no play in the turbo!
$1500
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0817.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0818.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0894.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0895.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0897.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0903.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0904.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0912.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0913.jpg)
exhaust on the flex is from where the screamer pipe was
Tial 50mm BOV, Silver comes with vband clamp and gasket , 11 psi spring
$150
Next is a HDI intercooler setup for a SC300. Has all the piping you need for a single turbo setup, all couplers upgraded to Samco ones and T bolt fittings $400
Does not include Tial but can be purchased extra
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0836.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0902.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0905.jpg)
Fluidyne MKIV supra radiator + Flex alight fans this is the best aftermarket cooling combo you can have $550 comes with a fan controller
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0822.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0823.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0906.jpg)
1 Recaro Pole Position SPG, GREAT shape only one small mark on it and you can see it in the pictures. FIA certified. super comfortable but im keeping my sparco Evo. $550
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0811.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0812.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0813.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0814.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0815.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0816.jpg)
Prothane front bushings SC300/400 not used
$45
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0842.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0920.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0921.jpg)
Precision 65lb injectors
$275
TTC Top-Feed Fuel Rail fed by -8AN line
$200
Aeromotive Fuel pressure regulator
$150 comes with -8an fittings, block off and a regular fuel hose fitting.
Screamer pipe
$1500
$150
$45
$275
$200
Wow! Your parting this thing out already? Baller! How wide is the seat? Im a pretty big guy but fit in Bride Brix II pretty snug but wondering how this is for bigger fellas.
And will it come with the rails?
yea im just parting out the stuff i have no need for basicly. I can include a memory fab seat rail with it if needed for $50 more. Im keeping the the bride rail since I like how its a dual locking rail. The seat I personally cannot fit in, I use a Sparco Evo 3, and it fits me perfect. but its my understanding its not a small seat. if you wanna make it to Columbus your more than welcome to sit in it but i understand that's a drive from you.
anyone interested in the engine + trans in stock form?
ive got a set of twins im going to put on it and convert it back to stock.
Will still have a new timing belt, water pump etc.
it will be missing the timing cover unless i cna find one, and an ecu...
PM me and we can talk about pricing that way.
