FS: Daizen Rear camber correction bushings in upper control arms
Up for sale Is a set of extremely rare Daizen rear camber correction bushings for the rear upper control arm. I already had them put into a set of low miles upper control arms from a SC300/400 setup to give me more camber but it can be easily switched. If I recall the arms had 20k miles on them, both ball joints are in good shape and the boots are perfect still.
These should fit a MKIV just fine as if I recall the arms are the same.
How difficult is it to swap them to the otherside for positive camber? Also once in place what's keeping them from auto adjusting after use ?
as far as i can tell they are in a oval shell and the bushing is ovaled as well. to flip them just gotta take the bushing out and flip it the other way.
