up for sale is a TRUE soarer r154, ( I know its a true soarer because it came from a half cut. I know its not an extended model but this is early model soarer)
$1700 OBO
Comes with the following,
R154
1jz bell housing,
C's Short shifter
Soarer 2 piece drive shaft
XTD clutch and pressure plate
OEM 1jz flywheel
OEM clutch slave
OEM clutch fork
OEM throw out bearing
OEM trans mount for sc300/sc400
OEM trans bushing
basically everything you need to convert from w58 to r154 or put it new on any 1jz/ 2jz motor.
What part of Ohio? I have been debating a swap... This may be the motivation I need.. i was just thinking to myself browsing the classifieds, that nobody is ever close to me so I could buy the larger items....
