OH fs sc300 / 1jz semi complete fuel system setup
Selling a almost complete fuel setup for a SC300.
Comes with Walbro 255, Fuel tank lid with 2x 6 an fittings in it, 2x 6an lines to a y block to a -8 line to a fuel filter all the way to the front to a Fuel injector clinic fuel rail feeding Precision 65# injectors and then back to an Aeromotive a1000 fuel pressure regulator.
the fitting that goes back to the regulator needs changed from a -6 and you will be good to go, you should add another walbro in tank and you willl be good. all lines are Aeromotive, all fittings are aeromotive, fuel filter is a jegs billet -8 an.
so in short
walbro 255
Fuel tank cover with -6 an fittings
-6 lines
-6 to -8 fuel block
-8 Jegs fuel filter
-8 line
Fuel injector clinic 1jz fuel rail
Precision 65# fuel injectors. (high impedance just wire them in and they are good to go)
aeromotive a1000 fuel pressure regulator with fittings and gauge
I would recommend redoing the fuel pump wiring.
$800 picked up for EVERYTHING!
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0825.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0942.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0982.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0984.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0985.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0986.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0987.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0988.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0989.jpg)
so in short
walbro 255
-6 lines
-6 to -8 fuel block
-8 Jegs fuel filter
-8 line
![](https://i18.photobucket.com/albums/b107/2zumeunos/Forsale/partout/DSC_0990.jpg)
