TX XSPower 2jzge FFIM
Brand new XSPower front facing intake manifold.
It comes with the plenum and bolts. This unit bolts directly to your stock 2jzge lower runners.
I've decided to hold off on the FFIM at this point in my na-t build because I just want the car to be running, now!
$350 shipped
This is my engine bay.
$350 shipped
![](https://farm8.staticflickr.com/7021/6661163263_2d81ff6a74_b.jpg)
You can tap it wherever you want to. Mark made it thick enough to tap for vacuum.
Far as TPS, you'd want to use a Q45 throttle body which has the tps, and idle up built into the TB. That's what I was going to do.
You'd need a throttle body, GTE power steering resevoir fitting so you can run a new ps reservoir. Intake manifold gasket.
