FL na-t dave h kit almost complete
NO TRADES CASH ONLY
$1150 SHIPPED, $1000 PICKED UP
NO IF ANDS BUTS ETC...I WILL NOT GO ANY LOWER THEN THIS SO DONT ASK, I AM NOT ACCEPTING ANY TRADES AT THIS TIME EITHER.
THANKS!!
Just as the title says, i have a dave h kit that im putting up so i can go 1jzgte instead for the cleaner install look..
Parts:
Precision 6176
compressor housing .60ar
turbine housing .63ar
(just sand blasted, turbine housing will get ceramic coated black tomorrow)
minimal shaft play
Dave H Manifold
was just sand blasted and ceramic coated
3" dp also just sand blasted will be ceramic coated tomorrow
Tial wastegate(i believe 38mm however im not 100%)
with dump tube also ceramic coated tomorrow
HDi Intercooler GT Spec 3" in/out
good quality brand more commonly used in AUS
Oil feed and return
all thats needed is bov and ic piping and whatever to control fuel and its
PICS(will have the rest tomorrow)
![](http://i44.tinypic.com/24qvig4.jpg)
THANKS!!
Parts:
Precision 6176
minimal shaft play
Dave H Manifold
Oil feed and return
![](http://i40.tinypic.com/2e6arvd.jpg)
Highly interested....looking to finally go boost but don't want to worry about piecing it all together. I like this particular setup because its not extremely fancy and I want it to look as OEM as possible. Only looking for 400hp or less. So besides the BOV, IC piping, and AEM, is there anything else needed?
What about injectors? I'm assuming RX-7 550cc injectors will do.
Also would I need to get a Wabro fuel pump for my particular application of just around 400hp?
Potentially going into a 97 SC300 so just wanting to make sure I get as much as I can in one shot and only have to get a few minor items. PM me if you like and we can sort things out. Thanks.
