CA FS: Yellow ES300 Projector Fog lights
I have for sale a pair of yellow projector fog lights off of a Lexus ES300. These can be used to retrofit into our fog lights there are some DIY's on this forum too. Come with just about everything besides the bracket. The projectors are good and the lens if you want to reuse them just need to be cleaned or polished. The bulb size are H3 just like ours but I don't know if they work as I've never hooked them up before. I'm selling these because I bought them to retrofit into my fogs but I haven't had the time to do it and I lost motivation after I let it sit for a while. Asking price is $60obo as that seems to be the going rate for these on forums which is better than ebay at $80+.
1of120's DIY
https://www.clublexus.com/forums/sc-...t-fog-hid.html
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-12201716.jpg)
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-12201804.jpg)
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-12201936.jpg)
OEM Springs and rubber boots off of my 1997 SC400. Worked perfect nothing wrong asking $40obo.
Universal 5mm spacers unused unmounted brand new. $20obo
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-17202933.jpg)
Also for sale US Amps/RE Audio AMP XT800.2 V3 brand new never used only opened to look at. Asking $65obo.
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-17203505.jpg)
![](http://i791.photobucket.com/albums/yy196/vangboi2/2012-05-17203442.jpg)
Specs for Amp:
Features:
XT800.2 V3 400 watt RMS (800w peak) 2 channel bridgeable car amplifier
800 watts peak output
200w x 2 RMS @ 2 Ohms
400w x 1 RMS @ 4 ohms
100w x 2 RMS @ 4 ohms
Bridgeable
Efficiency: 70 % @ 4 Ohms or 65 % @ 2 Ohms
Fully adjustable butterworth high and low pass crossover filters
High pass filter - adjustable 40 HZ - 1 KHZ @ 12 dB per octave
Low Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octave
Adjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZ
Subsonic Filter: 15-40 HZ @ 24 dB per octave
Low level Input
RCA Pre-amp output
Block Power Connector
Requires true 8 gauge power wire for installation
Screw terminal barrier strip speaker connectors
8 - 18 AWG speaker connector gauge
Aluminum heatsink
Convention cooling
power and protection LED Indicators
Class A/B
Frequency Response: 5 HZ - 50 KHZ
Weight: 7 pounds
Dimensions: 1.875" x 10" x 9.75"
I need to move these items because I have no room for them in my apt. Make me some offer guys worse I could say is no.
1of120's DIY
Specs for Amp:
Features:
Bridgeable
Low level Input
RCA Pre-amp output
Aluminum heatsink
Convention cooling
Class A/B
Weight: 7 pounds
I think Bender25 has these retrofitted into his Pre '97 SC. I'm sure it's the same concept as the 97+ as far as retrofit but you should ask some one who's actually done it just to confirm.
Bender25's car
https://www.clublexus.com/forums/sc-...ve-wheels.html
Bender25's car
Yeah I think everyone did do it to their actual fog light for there 97+ but for the 92 its only a corner light so it might not work. Doesn't even use a h3 bulb. I would have to get a connector and whatever that way too. I'll wait til I find someone that did it lol.
I have the OEM H3 harness coming off the fog lights all you'll need to do is hard wire in some H3 plugs to connect or you can splice it directly without using that connecter. As for turning corning lights into fog lights you'll need to splice into a power that turns on when your headlights do. If it was me I'd try to splice into the parking lights so the fogs can come on without the headlights coming on. Everyone does it different though but there are DIY's on that on here too. No problem let me know what you come up with.
Midengtoy
General Classifieds
07-23-12 10:58 PM
