HI 95 sc300 manual gauge cluster
I have one, but you will need the ribbons replaced from the back. Something is shorting causing the temperature gauge to keep rising and changing the ribbons will fix the problem (easy fix) . Other than that everything works.
If you have a auto 95 cluster you can take that apart and use the auto ribbons. In addition, the back circuit board keeps the mileage and using your old one will keep your original miles, if you didn't know already.
Let me know if you are interested or not.
