FL FS/WTT: Complete Air Suspension
$300 OBO
I purchased a complete air suspension from a friend of mine (SupradeDupra off of SupraForums.com and Tallyimports.com) with the intent of using it on my SC, however after thinking it over, went coilovers. I realize I dont post a ton on here, on Zilvia.net, 240atlanta.com and Tallyimports.com Im pretty active, feel free to check the same s/n there, or PM me for my phone number!
It is a complete set of air cylinders with holding tank and compressor. Has the controls, as well as all the lines. Independent front and rear lowering and a proportioning valve side to side for even distribution.
Front cylinders have SS braided lines, the rear use DOT airbrake lining. Tank is powdercoated blue, but has a few dings here and there.
THe only thing you would might need is DOT air brake tubing, which you can get at any Carquest or Napa for cheap. The amount you need really depends how you run the lines, so I would measure based off that. The stuff included is from how it was run here.
It worked perfectly upon removal, but could use a a bit of a refresher before installiation. i.e. replacing the burst valves (one is actually broken), re-teflon tape the fittings, etc.
Overall its a solid airride system for the cheap, Im a little more performance oriented with my swap on the horizon and am trying to grab some coilovers.
Open to offers, it comes in 3 boxes, Ive bubble wrapped and sealed everything up nice for shipping. Shipping should be around $60 for East Coast, around $80 for West Coast. I will cover the difference if it is higher
Broken Burst - (not from actually bursting, from careless handling during transportation)
I dont have any pics installed unfortunately, I have Tom's Advox on my car now and decided not to change for these. Im going to get some Stance's instead as Ill be a bit more track oriented. Ill have teh Tom's up for sale soon if anyone is interested in a perfect c/o for a daily driver.
SaUcE
SC400 / 300 Classifieds
12-16-09 07:35 PM
