CA 95% Complete Air Suspension Kit
Hello All!
Up for sale is a almost complete air suspension kit.
What you need to get it to work:
Wiring
Airlines
Air Tank
Air Tank Pressure Sensor
Loc-tite 545 or Teflon tape
Included in this kit:
(4) Universal Air Suspension AERO SPORT bags ($189 New, each)
(8) “Blow Proof” Solenoid Valves ($99 New, each)
(4) Variable air release regulators ($20 new, each)
(4) Dakota Digital Pressure Sensors ($40 New, each)
(2) 480 VAIR Air Compressors ($400 pair, new)
(1) Dakota Digital Ride Height Controller ($825 new)
(1) Remote Control Kit ($170 new)
(2) Relays for air compressor activation
(1) Large gauge wire + 60amp fuse for Air Compressors
(1) 5amp fuse for Dakota Controller power
(2) “T” Air Fittings
All plugs for the Dakota Controller included
So far that’s $3,183 total in (new) MSRP prices, not even including all the little things.
Asking Price: $1700 OBO, Emphasis on the OR BEST OFFER!
Had this on my SC300 with the bags on Tein CSv.2 coilovers. Worked like a charm! Had leaks when I first installed with Teflon, but I switched to Loc-tite 545 and have had no issues since then. This kit has been sitting in storage for a long time now. Resealing and cleaning all the connection points is very recommended. The controller displays all four corner’s air pressures. You can control each corner INDIVIDUALLY, FRONT or BACK, or LEFT and RIGHT. I also highly recommend air lines to be switched to ¼” inlet from the tank to the valves to slow down the rate the bags inflate. With the release regulator valves you can control how fast/slow the bags drop down.
I have included labeled pictures in case some of you don’t know what the parts are or how the valves work.
Contact:
Fastest Response: Text me @ (949)874-8881 (You can call, but I don’t pick up random numbers, leave a message and I WILL call you back!)
Email me: Tomleeisme@gmail.com
Lastly, PM me.
![](http://img.photobucket.com/albums/v203/chinesefood999/allcopy.jpg)
![](http://img.photobucket.com/albums/v203/chinesefood999/compressor.jpg)
![](http://img.photobucket.com/albums/v203/chinesefood999/controllercopy.jpg)
![](http://img.photobucket.com/albums/v203/chinesefood999/valves.jpg)
![](http://img.photobucket.com/albums/v203/chinesefood999/airbags.jpg)
My SC300:
![](http://img.photobucket.com/albums/v203/chinesefood999/SC300.jpg)
Wiring
Airlines
Air Tank
Contact:
Lastly, PM me.
My SC300:
![](http://img.photobucket.com/albums/v203/chinesefood999/sc.jpg)
I think they are better. When you increase PSI your suspension also stiffens. And they can be fitted on most coil over systems, as long as the tube is 2.25" or under I believe.
However....
Kit is PENDING SALE!
However....
swtjlsy
24
01-25-11 04:39 AM
/209JOHN\
12-30-08 09:12 AM
pbbnxiltae
01-27-08 08:57 PM
