FL SC 300 AC Climate Control
SOLD!
I have for sale a perfectly working, just had new LCD screen installed AC controller. Reason I'm selling is that I just received my Lextech upgrade with another AC controller.
Price shipped with Paypal fees: $90.00
Local Fort Lauderdale: $90.00 picked up.
Paypal ID: alverez954@gmail.com
I will ship it out via USPS on the next day after payment and msg tracking number.
Part number (You will find this on the top of the AC controller once you pull it out):
55900-24190
Make sure this works on your model SC300.
I'm not responsible if you don't match your part numbers.
Just a side note, if your AC controller works well, and just want to fix the LCD and my part number and yours don't match, you can separate the back half and the front and switch it with yours. The rear part controls the operation, the front half is the display. In other words you can connect your back half with my front. It's really easy. Remove two screws, release tabs on the outside and unplug two connectors. Reassemble with the steps in reverse. I've done it before with no problems.
It works perfect as pictures show prior to removal.
![](http://i19.photobucket.com/albums/b171/whensthenextparty/SMOKIN%20ACES/IMAG0610.jpg)
![](http://i19.photobucket.com/albums/b171/whensthenextparty/SMOKIN%20ACES/IMAG0613.jpg)
My new setup
(not for sale)
55900-24190
My new setup
![](http://i19.photobucket.com/albums/b171/whensthenextparty/SMOKIN%20ACES/IMAG0617.jpg)
I have supplied the part number for you to check. I'm not sure. If you read the description, it explains that if you are just trying to fix your lcd and your controls are fine, it's very simple as the front halves are interchangeable. It's the back half of the unit that is year specific. I know this, because I did it myself with another unit. It's really easy to do.
Hope that helps.
Hope that helps.
supaIS350
01-30-07 09:25 AM
