TX 2JZGTE - with a lot of mods 600HP READY!!!
2JZGTE with UPgraded packages- $2,300
JDM 2jzgte (non-vvti) - imported from japan so miles are always unknown i put about 40,000 miles on it
Head rebuild 8,000 miles ago
Came out of my running car making 19psi - 420 hp
wire harness was modded to work with my 1999 sc300 (all sensors included)
already sold the turbo system, and fuel system so i return the fuel system back to stock
Includes:
• Greddy style pulley
• K&N ivac filter
• ARP head studs
• Gates timing belt
• Mishimoto thermostat
• Modified polished upper water neck
• Chrome usdm water pump
• 440cc injectors
• Oem automatic ecu
• Oem transmission
• Oem crank pulley
• Sc400 drive shaft – direct swap for any sc300
• Ati crank pulley
• Aluminum pulleys
• Brand new serpentine belt
• 2jzgte ignitor
• oem map sensor
• oem tps
• Polished valve covers
• New a/c clutch
• Oil sandwich plate
• Driftmotion 200 amp alternator
• Sc300 oil sump pan
• Modified oil pan for oil return
• 4an Oil feed
• Modified spark plug cover
• Lower water hose
• Gapped copper spark plugs ready for 400hp
• Damaged intercooler pipe & intercooler (intercooler may or may not work, it’s a free bee)
buyer must pickup i will not ship the items from Houston, Texas
i will not part out anything
[IMG][/IMG]
Asking price $2,300.00 FIRM!!! NO TRADES
Includes:
• K&N ivac filter
• ARP head studs
• Gates timing belt
• 440cc injectors
• Oem automatic ecu
• Oem transmission
• Oem crank pulley
• Ati crank pulley
• Aluminum pulleys
• 2jzgte ignitor
• oem map sensor
• oem tps
• New a/c clutch
• 4an Oil feed
• Lower water hose
[IMG][/IMG]
that is a blk has with an empty cluster, fyi cluster has been sold, i believe this would be a direct swap for a sc400
google helped me find this: https://www.clublexus.com/forums/per...wap-guide.html
the only thing you would need to get is new motor and tranny rubber mounts, which you can buy a set from ebay megan motor mounts
to make this deal even better, i also have a map for mapecu1, that i will give the buyer for free !!! so no tuning will be required so once installed ready to drive
setup for:
greddy (denso) 720cc
fpr
borg warner s366
tail 38mm wastegate
mapecu 1
greddy bcc
made 420hp (sorry no dyno sheet) that i paid for $500 to get tuned
setup for:
fpr
borg warner s366
tail 38mm wastegate
mapecu 1
greddy bcc
also someone is selling the harness for sc400 2jzgte
https://www.clublexus.com/forums/sc4...-auto-ecu.html
will help speed the install a lot smoother
