FL 75lbs 750cc bosh/Lucas/Delphi fuel injectors
LUCAS LUCAS IMPEDANCE 75LB/750CC FUEL INJECTOR
![](http://i62.photobucket.com/albums/h119/badboi954life/image.jpg)
Genuine Delphi 75 lb/hour High Impedance Injectors ( Alcohol Compatible )
They have been flow tested in January, everything came back 100%
Car has been down since then for new setup![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Drops into oem fuel rail (that's how I ran them) comes with everything to install and drive
These injectors flow 750 cc/min at 43.5 psi ) and are fully compatible with alternate fuels and alcohol! Some websites may refer to their flow rating as 72 lb/hr or 75 lb/hr or 750/780 cc/min Delphi Saturated or High-Z Injectors. Frequently used in racing, flex fuel applications and alternate fuel applications, these low impedance injectors combine extremely high flow rates with excellent response at low pulse widths! This allows you to use a larger injector than normally possible without hurting idle and low speed drivability.
ADVANTAGES:
The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
Compatible with alternative fuels (i.e. E85, Methanol)
High-speed disc action allows wider dynamic flow range for improved idling
Revolutionary disc design resists build up deposits which can affect fuel flow
No Fuel leakage for quicker start
Specifications:
Coil Resistance: 12.2 Ohms / High Impedance
Spray Patter: Tri-Cone
Physical Dimensions: EV1 Body Type
Connector: Bosch EV1
Equivalent Part Numbers:
Delphi 621060
Lucas 01D129B
Model: 621060
Manufactured by: Delphi
Looking for $200 obo shipped to any of the 48 states
PayPal: BAD954BOI@yahoo.com
ADVANTAGES:
Specifications:
Delphi 621060
Lucas 01D129B
Model: 621060
tonysc400
SC400 / 300 Classifieds
01-31-13 10:44 AM
