AL FS: Random stuff for SC300/400 and 1JZ
1JZ Single SC400
I have been trying to clean up the garage a little and here is what I have. Prices are OBO and does not include shipping cost. If you pay through Paypal, my address is marklinley36@gmail.com and add 3% for fees unless you pay as a gift. Look at my trader score, so buy with confidence. Some of this stuff will be good to have extra of..
Hubcentric rings for rims, mine were size 19. I have only three of them but in good shape. $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122020a.jpg)
Set of Infinity Rays center caps, in good shape, no broken tabs and all metal clips intact.. $25.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122020.jpg)
TPS sensor for the 400, unknown of all years it will fit, but I believe all of them, 1992- 2000. $30
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122018.jpg)
Used slotted and drilled front brake rotors for SC400, some rust but will clean up nicely. $40.00 for both, only showing one.
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122017b.jpg)
Map sensor for 1JZ. $40
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122017a.jpg)
Lexus rear trunk emblem, I believe will fit the front also, all tabs are broken, but can be glued on. No scratches. $5.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122017.jpg)
HKS turbo timer, the plug in is meesed up, tried to repin back in, but I am not good at it. Still works and comes on. $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122016a.jpg)
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122016.jpg)
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122015b.jpg)
SC400 tranny mount $25.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122015a.jpg)
Trac sensor in intake manifold for the SC400.. $30.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122015.jpg)
Rear strut rods and bars... $15.00 each or $30.00 for all
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122014a.jpg)
1JZ valve cover, only one I have.. $40.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122014.jpg)
1JZ fuel rail with fuel pressure regulator... $40.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122012c.jpg)
Rear section of drive shaft for the SC400 only.. $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122012b.jpg)
Rear upper control arms for SC300/400.. $30 each or $50.00 for both, with good bushings.
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122012a.jpg)
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122011a.jpg)
1JZ/2JZ drive pullies, for power steering, alternator, and water pump.. $30.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122012.jpg)
Rear section of a automatic SC300, great for swaps to R154. $50.00, good bushing, no cracks
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122011.jpg)
Front, both sides inner fender liner, no cracks comes with plastic tabs... $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122010b.jpg)
1JZ Single SC400
Plastic interior for SC300/400, $10 each or $30 for both...
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122010a.jpg)
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122010.jpg)
All parts will be cleaned up before being shipped out. When you pay, I will try to ship out same day, thanks for looking.
1JZ Single SC400
Cross member for the SC400, stock piece of aluminum. $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122009.jpg)
Plastic piece to cover the ECU in the passenger side compartment... $20.00
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122009b.jpg)
Tokico Blues struts with top hats, no springs. I know it shows the springs but will be removed. Front only. $90.00, only have about 8K miles on them.
![](http://i1106.photobucket.com/albums/h364/1992LexusMarks/1002122009a.jpg)
Biggu
SC400 / 300 Classifieds
30
07-10-12 08:29 AM
