TX NEW Cusco chromoly 4 point roll bar / cage
Old 11-20-12, 12:39 AM
Kohinoor
Kohinoor's Avatar
bump>>>>>>>>>>>>>>>>
Kohinoor is offline
Old 11-28-12, 06:27 PM
Kohinoor
Kohinoor's Avatar
Kohinoor is offline
Old 12-04-12, 09:57 AM
addisonblc
addisonblc's Avatar
Bump for a good dude. Damn sweet price too. If you doubt it price match that *****.
addisonblc is offline
Old 12-04-12, 02:10 PM
vakamon
vakamon's Avatar
Default Roll cage
If u still got this after x-mas ill pick it up from you... No doubt
vakamon is offline
Old 12-05-12, 06:56 AM
TheRonTom3
TheRonTom3's Avatar
Question. I'm not familiar with these for the SC, can you add more bars to this. Like the front A pillar bars to get the 6 point or is it ordered as 6 point and the joint welded together?
TheRonTom3 is offline
Old 12-05-12, 08:47 AM
Kohinoor
Kohinoor's Avatar
Yes there are addon bars available. The front 2 or 3 to make it 6/7 point, there are also crossbars available for the rear section - diagonal and horizontal - which would make it an 8-9 point bar with the front. rhdjapan.com has all of them iirc.
Kohinoor is offline
Old 12-10-12, 09:46 AM
Kohinoor
Kohinoor's Avatar
Kohinoor is offline
Old 12-20-12, 06:10 PM
Kohinoor
Kohinoor's Avatar
Kohinoor is offline
Old 12-30-12, 05:38 PM
Kohinoor
Kohinoor's Avatar
Kohinoor is offline
Old 01-06-13, 09:42 AM
Kohinoor
Kohinoor's Avatar
price drop to $500 shipped firm
last call before I just install it
Kohinoor is offline
Old 01-08-13, 10:21 AM
iridebmx
iridebmx's Avatar
just out of curiosity though i don't plan on buying unfortunately. where do they bolt up? and wouldn't you have to cut the rear deck for the 2 rear bars to go in the strut brace section?
iridebmx is offline
Old 01-08-13, 10:24 AM
Kohinoor
Kohinoor's Avatar
The large bar bolts to the floor at each side and the smaller ones just behind the rear seat at each side. It does not go through the rear deck and it retains the rear seats, albeit it will be 'squeezed' slightly because of the bars.
Kohinoor is offline
Old 01-15-13, 07:22 AM
Kohinoor
Kohinoor's Avatar
$500 shipped or $450 picked up
Kohinoor is offline
Old 01-15-13, 03:44 PM
iheartmysc
iheartmysc's Avatar
Do you know if this will fit in a supra (jza80)?
iheartmysc is offline
Old 01-15-13, 05:50 PM
Kohinoor
Kohinoor's Avatar
I think one can assume they would be similar in dimension, but they are different part numbers - so I can't confirm that for you.
Kohinoor is offline
Quick Reply: TX NEW Cusco chromoly 4 point roll bar / cage
