95 SC400 ECU (w/ NOS timing)
this is the ECU upgrade sold via lexuspros.com with the nitrous timing.
normal cost is 849$ + 199$: 1049$
I'm asking 600$
This will be a swap of ECU so I will need your part# of your ECU to make sure that it is the same model so that NO problems will occur. My ECU is a 95, but if you have a 92-94 it might work but I will still need your ECU # to be sure.
any questions or requests, and you can email me
nick@lexusport.com
Thanks.
I'm asking 600$
nick@lexusport.com
Thanks.
Depending on what happens with A51, i will be going forced induction. With FI, the ECU needs to be adjusted anyways so it would be a waste of an ECU if I just re-modify an already modified ECU. Someone else can take advantage of it.
also, the Part # (for you guys who want to check) is
89661-24410
It's directly under "Toyota" in the black box in the center of the sticker.
89661-24410
cartmill
SC400 / 300 Classifieds
12
05-17-11 09:47 PM
