FL Complete sc400 v-8 swap motor,trans,ecu wirig etc 800.00!
Ok so am getting ready to pull this out in the next couple of weeks and this is a well maintained swap from my 97 sc400 and will come with motor,trans,ecu,wire harness,maf sensor,etc etc
Why am I sellig it so cheap? simpley because I have no space to store it Local pick up at this point as of now, located in 34748 FL
New power steering pump,
New alternator
New valve cover gaskets
Fresh tune up
ran on royal purple oil
No slude or exhaustgas build up as you an see from the pics
I have a vid of it running and driving cold stat and hot start, Trans had only oem tiv fluid
New alternator
Fresh tune up
This swap will go on craigs list when it is pulled but CL has 1st crack at it
I may part this out as I can end up with much more than my package price.
Starter
Alt
p/s pump
All new so there is almost 500.00 just in new parts so this deal is very good for a lower mileage 1uzfe swap which runs like new in all honesty.
Only reason for pulling it is for a gte $wap other wise it would surely go another 100k plus miles with no doubt as all of the trouble areas are fixed!
Starter
Alt
p/s pump
