Need a TPS Please
Ok So I Broke weak and went out and bought a new TPS .The TPS on my 92 SC400 had the part # 89452-12050 The new TPS had the part# 89452-22090 is that ok?? I installed it and it feel like its driving fine.I did some research and from what I read the new 89452-22090 replaced the old 89452-12050 ?????
If I had them look up the Year make and model its a $163 part and special order, but if they cross reference the old 89452-12050 the price was $79.99 With the part# 89452-22090??? I am just confused LOL! Please help
89452-50010 (04/1991 - 08/1992) which supercedes to 89452-50020
89452-50020 (09/1992 - 12/1993)
However the part number 89452-12050 supercedes to:
89452-22090 toyota
89452-33010 lexus but multisupercedes to 89452-22090
So either toyo-diy is wrong or you have the correct part. I would call Curt Aigner at Elmhurst Toyota. He may shed some light on the situation. I think the number stamped on the TPS may be for something else and not the part number.
If you gave the lexus dealer a vin number, then I wouldnt worry about getting the wrong part number.
according to toyo-diy the part number is:
89452-22090 toyota
89452-22090 toyota
1WILLY1
The plugs on the TPS and Sub TRAC TPS are keyed different
From what I am finding is what you 1st said was right the -50010 supersedes to the 22090 at somethe point. The car still seems ok after a 50 mile drive, it took some time to get the TPS adjusted right though. Only CEL code I am still getting after clearing the codes is the 25 lean code the 41 TPS has not come back so far.... Time will tell
1991, 8945212050, 8945250010, 8945250020, cross, install, is400, lexus, number, part, place, refrence, sc400, tps, work
