CA 2JZGTE & other supra turbo parts, coilpacks, sensors, downpipe, ARP studs, wheels etc
What is your First & Last name? Al Rhee
What is your email? tiraceteam@turboimport.com
What is your phone number? -Optional: 714-930-6404 (no texts please)
What is your City? : Fullerton
What is your State? : CA
clearing out some of the stuff I don't need anymore.
shipping is not included. local pick up in so cal preferred.
DO NOT PM
email tiraceteam@turboimport.com if you want any of these parts
used CP pistons (high compression) - complete set- $300
all have some scoring along the sides due to an oiling issue. I believe they are all salvageable, but I suggest talking to your machine shop and see what they say. I'll have pics posted soon or just email me.
used ARP main studs complete set- SOLD
used ARP 1/2 inch head studs complete set- $80
complete set of used stock main studs & 1/s inch head studs in perfect shape. They are pretty much new. They were installed but came right back out because the motor was torn apart after initial startup
1/2 inch ARP head studs shown:
![](https://lh5.googleusercontent.com/-YDpXQ6qkaMI/UcyeP3Akz_I/AAAAAAAAAhQ/SzkDfw13pj8/w600-h370-no/half_inch_arp.jpg)
stock 2jzgte oil cap - $5
stock cam gear timing back plate - $5
this is the black piece that sits behind the gears
![](http://turboimport.com/temp/2jz_rear_plate.jpg)
2JZGTE cam angle sensors - $25 each
![](http://turboimport.com/temp/sf/cam_angle_sensors.jpg)
I have 4 available. The ones in the pic are sold. Others are also in good used condition.
JDM upper intake / intercooler piping for stock twinturbos - $10
USDM supra 2JZGTE throttle body - $75
Stock fuel rail upgraded with -6 fitting & stock fuel pressure regulator- $15
good for you guys trying upgrading to side feed 720's or just trying to get a little more out of your stock fuel system.
![](https://lh3.googleusercontent.com/-f7FyyZVj_Go/UbWHcTNQopI/AAAAAAAAAcY/Q5q1t5fY8dM/s800/stock_fuel_rail.jpg)
stock 2JZGTE rods - $25
selling cheap because 3 of the rods have some scratches where the wrist pins go in due to an idiot that pulled the pins out incorrectly upon disassembly. These will need to be machined and cleaned up or you can have new bushings pressed in. Other than that, they are in great shape. The other 3 are in good used condition so they would make great spares if you bent a single rod or two. I priced the entire set cheap to offset the machining costs.
![](http://turboimport.com/temp/sf/scratched_rods.jpg)
stock 2JZGTE main caps complete set- $20
complete set of used stock main caps in great shape. removed because motor was built with billet mains
stock 2JZGTE twinturbo VSV's- $25
I got a whole bunch of VSV's for the stock twinturbos. vary in price but most at $25
EBV - 90910-12114 , IACV - 90910-12126-A , Wastegate VSV - 90910-12115 , 90910-12127-A, 17630-46050 , IACV - 90910-12114 , EGCV - 90910-12127 , EBV - 25860-46060, WASTEGATE - 90910-12115 , FPR - 90910-12014 , EVAP - 90910-12175 , EGR - 17630-46060
2jzgte coilpacks & brackets - $150
(60k on this set. The other NEW set costs more so be specific on which set you want when inquiring)
bunch of good used stock parts
2jzgte coilpack mounting brackets x3 - $10
2JZ oil filter bracket - $20
2JZ accessory belt pulley - $10
4 bolt wastegate flange w pipe - $10
stock USDM turbo - good unit - $40
2JZ oil pump cover - $10
2JZGTE lower intake manifold runners - $70
2JZGTE water pump with pulley, thermostat, & outlet- $80
2JZGTE water pump only $40
2JZGTE crank sensor - $30
2JZGTE oil pressure sensor - $5
2JZGTE cam position sensor - $20
2JZGTE water temp sensor - $5
2JZGTE knock sensor - $8
![](https://lh3.googleusercontent.com/-ob-KiP-saeE/UcyeHNZtGHI/AAAAAAAAAgg/1yKzs-TT9Lc/w800-h600-no/2jzgte_parts.jpg)
![](https://lh5.googleusercontent.com/-9kVyBMCeKgQ/UcyeHVjCoAI/AAAAAAAAAgo/SKRnQ9CdS7U/w800-h600-no/2jzgte_sensors.jpg)
JDM 2JZGTE ECU - $70
for automatic trans models but also works fine for manual trannys. The main difference from US spec is that these are calibrated for the smaller JDM 440CC injectors & no MAF sensor.
power steering tank - $20
works fine but it has a dent in it and and bent bracket. NA guys swapping over to the 2JZGTE will need this.
![](https://lh5.googleusercontent.com/-Ama4x6wvBDI/UbmrzfsmG2I/AAAAAAAAAd4/w2LL8PKgFAI/s800/power_steering_tank.jpg)
used timing belt tensioner - $10
good used unit from a 60k mile motor. I have 2 available. same condition
![](https://lh5.googleusercontent.com/-iWYyOfmfTb8/UbWNOr11nHI/AAAAAAAAAco/ibGZysoldGA/s800/017.jpg)
JDM 2JZGTE stock twinturbos- $30
unknown condition. *turbines still spin freely but not so smooth. *good solid core for a rebuild from speed for sale or anyone else that modifies these. Keep in mind these are HEAVY. Shipping will probably cost more than I am asking for the turbos.
![](https://lh6.googleusercontent.com/-l2B_SZn1Z_c/UbWTQzJxj5I/AAAAAAAAAdg/8K0vf-66hy4/s800/jdm_twins.jpg)
4 inch AEM intake & polished pipe for single turbo - SOLD
polished catch can - $15
Boost Logic oil feed and return lines kit for single turbo - SOLD
![](https://lh5.googleusercontent.com/-10tH-xFfOyY/UcyePIOZuiI/AAAAAAAAAhI/CJmH6nOC5IM/w600-h424-no/2jzgte_single_parts.jpg)
used 92 SC300 charcoal cansiter - $5
used mkiv supra turbo charcoal cansiter - $20
2JZGTE main throttle position sensor (TPS) - $40
2JZGTE TRAC throttle positio sensor (TPS) - $20
2JZGTE coilpacks (complete set of 6) - $440
part # 90919-02205 - basically BRAND NEW. Ran them for less than 500 miles. I never rebuilt that motor from my old car so these are up for grabs. Will not separate. Must buy all 6. Includes all the original Toyota boxes. They are in PERFECT shape besides a little greasy streaks from my dirty hands. I have another used set with 60k miles listed here so please specify which set you want when inquiring.
93-98 supra turbo EGR assembly - modulator& valve - $40
![](https://lh3.googleusercontent.com/-tZZ6Me6o9yg/UcyeJ0rynDI/AAAAAAAAAgw/fpcGB9dfAL4/w600-h488-no/2jzgte_egr.jpg)
black flex fit style supra logo hat - $17 shipped
still brand new
![](https://lh6.googleusercontent.com/-N_u5UwqTFRk/UeB9KYT5gOI/AAAAAAAAAoE/YDz-nOos0l0/w969-h723-no/suprahat.jpg)
98 supra NA rear end - diff & axles - $600
prices do no include shipping or paypal fees.
DO NOT PM
still brand new
SeoulMan24
SC400 / 300 Classifieds
22
10-20-13 09:02 AM
blackkarma
09-19-13 06:40 PM
