FL FS: Motec M8
FS: Motec M8
Janelle Conte
Orlando, FL
$1200 obo. I'll ship it or you can pick it up.
General M8 info:
CPU Motorola 32-bit @ 33MHz
Max Cylinders 12
Fuel Maps 40
Ignition Maps 40
Load Points per Map 21
Total Fuel Points 840
Total Ignition Points 840
Fuel Correction Maps or Factors Coolant Temp, Air Temp, Full Throttle, Closed Throttle, Battery Volts, Cold Start, Throttle Pump, Injector Trim
Ignition Correction Maps or Factors Coolant Temp, Air Temp
Injector Outputs 4
Ignition Outputs 4
Auxiliary Inputs 2
Auxiliary Outputs Max 3 (Depending on Number of Cylinders)
O2 Sensor Yes (Wideband)
Closed Loop Operation Yes
Data Logging Yes
Boost Control Yes
Traction/Launch Control Yes
Nitrous Management Yes
VTEC Control Indirect (RPM Operated output)
Anti-Lag Yes
Flat-Shift Yes
PC Programmable Yes - DOS
Handset Programmable No
Janelle Conte
Orlando, FL
General M8 info:
Max Cylinders 12
Fuel Maps 40
Ignition Maps 40
Injector Outputs 4
Ignition Outputs 4
Auxiliary Inputs 2
Data Logging Yes
Boost Control Yes
Anti-Lag Yes
Flat-Shift Yes
