GA sc300 turbo r154 part out-
Old 09-16-13, 07:56 PM
navazsc3
navazsc3's Avatar
Default sc300 turbo r154 part out-
sc300 parts for sale. The car has a NA 2jz with a r154 built with all new Marlin Crawler parts by SpeedforSale.
I will only sell the major parts-Transmission, Clutch & Flywheel, Engine, Turbo/manifold/wastegate/downpipe
Parts list.
Drivetrain
(everything under drivetrain was bought new except the driveshaft/transmission)
Built R154 Marlin Crawler by speed for sale
Marlin Crawler Shifter Socket R154
ACT TS2-HDG6 Clutch Kit
R154/W58 Bell Housing to Transmission Bolt Set
1JZ/2JZ Bell Housing Bolt Set
Clutch Slave Cylinder R154
Full Length Clutch Hose
1JZ Lightweight Flywheel 11.5lb for R154
ARP 1JZ Flywheel Bolts
Clutch Release Hub Kit R154-Washers/Clips/Hub
Pressure Plate Bolt Set R154
R154 Fork Support with Spring
Marlin Crawler Urethane Shifter Bushing For R154 Transmission
Supra/sc300 2 piece driveshaft
Engine(NA 2JZ)
-Every gasket is new and has a brand new oil pump
Ceramic coated Turbonetics log style manifold and ceramic coated turbo 60-1 .68 A/R
deltagate wastegate exiting into the downpipe
Aluminum Intake with K&N filter
3 Inch downpipe
xs power metal head gasket
arp head studs
turbo lines and fittings installed
oil sandwich plate adapter
custom made MSD 8.5mm wires
Aluminum lightweight pulley kit
440cc and stock injectors included
Walbro 255lph Fuel Pump
2 row aluminum radiator
Welded 4.27 diff
5 Speed swapped
Call or Text 678-983-1469
$4000obo for everything, will consider trades plus cash
navazsc3 is offline
Old 09-16-13, 07:57 PM
navazsc3
navazsc3's Avatar
chnk can vouch
navazsc3 is offline
Old 09-16-13, 08:01 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,238 Likes on 1,357 Posts
Originally Posted by chnk
vouch above
DaveGS4 is offline
Old 09-21-13, 01:24 PM
jaysus101
jaysus101's Avatar
how much for the complete r154 and clutch?
jaysus101 is offline
Old 09-21-13, 08:02 PM
IIJZSC300
IIJZSC300's Avatar
How much for the rad shipped to 19904
IIJZSC300 is offline
Old 09-22-13, 08:08 AM
navazsc3
navazsc3's Avatar
Sorry guys, only thing left is the white lenso wheels
navazsc3 is offline
BigNasty
Performance & Maintenance
11-28-14 03:13 PM
Slow_Sc3
SC400 / 300 Classifieds
13
07-03-11 03:08 PM
broda805
SC- 1st Gen (1992-2000)
05-01-11 06:48 AM
TLDriver
18
01-20-09 09:57 PM
ummagawd
29
01-09-06 04:39 PM
Quick Reply: GA sc300 turbo r154 part out-
